mediator123
Nov 28, 2009Aspirant
Problems using SyncToy 2.1
Hello everyone, I´m almost going crazy with my ReadyNas Duo! Since August I´m trying fix the following problem (with the help of Netgear support), unfortunately without any success! I had a Win...
dbott67
Dec 03, 2009Guide
mediator123 wrote: 1.) If I set the schedule for the synchronisation, is it somehow possible to make the PC startup automatically?
Most computers support some sort of "wake" feature in the BIOS. Check there to see if your computer can be set power on via schedule.
mediator123 wrote: 2.) I realized that my NAS has no static IP adress. This might lead to troubles becausethe NAS´s IP adress is named in the DeltaCopy Client. Is there a workaround?
The ReadyNAS can be configured to use a static IP (Frontview > Network > Interfaces). Additionally, many routers now support "DHCP Reservations" (also called static DHCP) where the same IP address can be reserved for a specific device. Check you router's manual to see if it supports it.
mediator123 wrote: In my opinion it is a little slow (who cares as long as it works?), but for future updates I don´t have to copy all the files so it won´t take that long I guess.
That's right... it is slow the first time, but subsequent backups are faster. Read this post for a little more info:
viewtopic.php?f=4&t=35911&p=200656#p200627
-Dave
