mediator123
Nov 28, 2009Aspirant
Problems using SyncToy 2.1
Hello everyone, I´m almost going crazy with my ReadyNas Duo! Since August I´m trying fix the following problem (with the help of Netgear support), unfortunately without any success! I had a Win...
pksparks
Jan 10, 2010Aspirant
Hi there, i have something i think looks like the question mediator123 has:
first of all i want to sync 1 or more directories on a pc, where i put in my checked mp3's, with the netgear readynas duo. i think i can use the whole story as described by dbott67. so far so good. but i also want to have all the data from the NAA copied to a 1TB usb disk, and like first a complete copy and after that to have it synced with eachother. so whatever i put on the NAS, must be copied to the usb disk, and what i remove from the NAS must be removed from the usb disk. i want to connect the usb disk to the NAS, and have it synced every week or so. then i can store the usb on a remote location, but also use it on another pc.
is that possible??
Rgds
Patrick
is that possible??
Rgds
Patrick
