mediator123
Nov 28, 2009Aspirant
Problems using SyncToy 2.1
Hello everyone, I´m almost going crazy with my ReadyNas Duo! Since August I´m trying fix the following problem (with the help of Netgear support), unfortunately without any success! I had a Win...
sdouek
Mar 11, 2011Guide
Just an after thought I do not know if this is posted anywhere but if you lock down your Windows PC's with the firewall you may have to add the exception port 873 so that the Deltacopy Server works from the PC. I had this working on my friends pc and then when I went to set it up on mine it took me a little time to figure that the port 873 was not being allowed. I feel very sheepish.
