mediator123
Nov 28, 2009Aspirant
Problems using SyncToy 2.1
Hello everyone, I´m almost going crazy with my ReadyNas Duo! Since August I´m trying fix the following problem (with the help of Netgear support), unfortunately without any success! I had a Win...
gpnas
Feb 17, 2013Aspirant
Hi,
I'm using the configuration detailed here to copy from ReadyNAS to a DeltaCopy Server on a Windows PC. But I've a problem. I've done exactly all dbott67 instructions.
The problem is that when configuring the job on the ReadyNAS, the "test connection" only works ok if I leave blank the "path" information. I write the server name only and the user name passowrd, then I do the "test connection" and works ok. But then I write down the path and it fails the check. I don't know what I'm doing wrong...
Any help is welcome.
Regards
Regards
