MC1967's avatar
MC1967
Problems with READYNAS system (strange system errors)
So, I purchased a used 3200 on Ebay, that the seller listed as working, but had no drive caddys. I also happened to have a couple extra motherboards for a 4200v2 (one with a  E-3450 CPU in it already...
  • Sandshark's avatar
    Nov 10, 2021
    Is the board you used from an RN4200 (lacks IPMI) or an RD5200 (has IPMI)?  They have identical part numbers.  If it's from an RD5200, then the IPMI and OS are likely having collisions WRT monitoring the board.  See the SuperMicro X8SI6 documentation as to how to disable the IPMI.
    If that's not it, maybe it's the board that controls the redundant power supplies, though I'm not sure why that would cause fan errors.
    A problem with the system configuration file could also cause this, but I don't see in your process how that would have happened.  The config for a 4200V2 in early OS6 was wrong, but it's been right for a while now.
    I did the conversion you did and had no issues with it.  Since you cloned the boot USB, the two NAS should show the same serial number, which will cause issues if you ever run ReadyCloud, but nothing else should cause a problem.
ProSupport for Business
