gbeddow
Apr 24, 2019Luminary
Problems with RN202 upgrade from 6.9.5 to 6.10.0
Hi,
I upgraded an RN202 from 6.9.5 to 6.10.0 today and many things are broken now. So many, in fact, I won't list them all (yet) but let's start with basic stuff that should work, but doesn't, like installed applications. All of the following now have "bad" configurations and no longer work:
linux-dash
LogAnalyzer
PHPMyAdmin
PHPSysInfo for ReadyNAS
At least the ReadyNAS admin page comes up (it wasn't for a while) and I can get in via ssh.
What's up?
1 Reply
- Retired_Member
Hi gbeddow, I had issues with linux-dash in conjunction with smb-plus under 6.10.0, too. After 6.10.1 is available I removed both apps from the system (RN104) and installed them successfully again. First smb-plus and second linux-dash. Now both work fine. This of course must not be a solution for you, but you might want to try to adopt the approach to your situation. My impression was, that linux-dash did something to php components/configuration. As all 4 apps you mentioned are heavily php-related it might be worth a try. Kind regards
