afarensis
Apr 19, 2017Guide
Problems with sharing files from IP-camera to ReadyNas 102
Hello, I have an Eminent EM6260 IP camera. I use the camera also for storage camera-images on my Netgear NAS 102. I can connect the NAS. From the settings I can access the NAS by using but...
Apr 19, 2017Guru - Experienced User
Can you confirm that the camera is using SMB (windows file sharing)? Often they use FTP or sometimes NFS.
afarensis wrote:
The structure of the shares is \\readynasos\data\Data\Camerabeelden, but that do not work.
Normally the data volume is named "Data".
If you have a share named "Data" you should rename it to something else using the web UI. You can run into some odd problems if you have a share with the same name as the data volume.
I also suggest creating a share named Camerabeelden (again with the web UI). If you do that, the correct access with SMB \\readynasos\Camerabeelden
- afarensisApr 19, 2017Guide
Thank you very much for your quick reply....
I don't no the answer on the first question. I have asked on the Eminent-forum. You here as soon as possible....
George
- afarensisApr 21, 2017Guide
Hello,
Sorry for late reply...
The camera is using FTP. I have change that. See attachement
I have change the share-name Data into Kopie-dataas you suggest.
I have tried the following combinations, but... is still doesn’t still works :smileysad:
- FTP \\readynasos\Camerabeelden (sure there is a space between FTP and \\?
- \\readynasos\Camerabeelden
- \\readynasos\data\Camerabeelden
George
- StephenBApr 21, 2017Guru - Experienced User
Did you try /Camerabeeden (and Camerabeeden) for the path?
The \\readynas format is only for Windows file sharing (SMB).
