afarensis
Apr 19, 2017Guide
Problems with sharing files from IP-camera to ReadyNas 102
Hello, I have an Eminent EM6260 IP camera. I use the camera also for storage camera-images on my Netgear NAS 102. I can connect the NAS. From the settings I can access the NAS by using but...
afarensis
Apr 19, 2017Guide
Thank you very much for your quick reply....
I don't no the answer on the first question. I have asked on the Eminent-forum. You here as soon as possible....
George
afarensis
Apr 21, 2017Guide
Hello,
Sorry for late reply...
The camera is using FTP. I have change that. See attachement
I have change the share-name Data into Kopie-dataas you suggest.
I have tried the following combinations, but... is still doesn’t still works :smileysad:
- FTP \\readynasos\Camerabeelden (sure there is a space between FTP and \\?
- \\readynasos\Camerabeelden
- \\readynasos\data\Camerabeelden
George
- StephenBApr 21, 2017Guru - Experienced User
Did you try /Camerabeeden (and Camerabeeden) for the path?
The \\readynas format is only for Windows file sharing (SMB).
- afarensisApr 22, 2017Guide
Hello,
Unfortunately, even with the two proposed options it will not succeed. Unless you have another good idea, it doesn't seem to get work. A great pity.
Kindly regards,
George van der Ven
- jak0lantashApr 22, 2017Mentor
You could try to create a normal user, give that user r/w permission on the FTP share and try with that on the software. Can you show the settings of the FTP service on the NAS?
