MWeigand's avatar
MWeigand
Procedure to transfer HDs to replacement NAS without data loss?
A 4 month old RR4312S died on me last weekend after a sheduled power outage (only blue light flashing, Boot menue inaccessible, USB boot, CMOS battery removal, HD removal, etc all failed to do anythi...
  • StephenB's avatar
    Apr 25, 2018
    If you get another OS6 rack-mount, then all you should have to do is migrate the disks with both machines powered off (ideally preserving the slot order).  Then power up.  If the new unit has a newer version of OS6 in it's flash, then the boot process will also upgrade the OS partition on the disks.
    Though if the power outage did some damage to the disks (or corrupted the file system) then you might need help from Netgear's paid support.  I suggest booting up the replacement in read-only mode the first time, and then confirm that all the data is intact.
ProSupport for Business
