readyornot
Apr 24, 2012Aspirant
Proper Duo Network Config
I use my Duo v1 to run Backup on several desktops at home. Name resolution has been hit-or-miss over the years, and before I upgrade to a x86 product I would like to see if I can make this old box per...
Apr 26, 2012Guru - Experienced User
You could try simply disabling WINS in the NAS as a test, then see if any symptoms change. If not, just turn it back on.
On the "bad" IP address - I am wondering if there is a possible IP address conflict? Does the log give any more information?
