mrQQ
Feb 11, 2016Apprentice
Proper way of reducing fan speeds
Hello, now that ReadyNAS OS 6 has smart fan speed control built in, what would be best way to reduce fan speeds at the cost of increased system temp? Installing fanspeedcontrol would conflict wit...
mdgm-ntgr
Feb 11, 2016NETGEAR Employee Retired
The fan speed should automatically reduce gradually if the temps fall and remain below a threshold.
The Ultra 4 fan needs to run reasonably quick to keep the PSU cool.
- mrQQFeb 19, 2016Apprentice
Hello,
I am aware of that, and yet I would like to make them run slower, how can that be done?
- cpu8088Feb 19, 2016Virtuoso
heat will shorten hard drive life, also affect cpu, motherboard, memory and power supply longevity
suggest not even think about reducing fan speed
- mrQQFeb 25, 2016Apprentice
Well you are just stating the obvious.
System temperature is 30c, cpu is 41 and the fan is too loud.
There is absolutely no issue if it would run at 40c + 50c.
So again, is there a way to reduce fan speeds at idle?
