Stuuk1
Feb 02, 2014Aspirant
PS3 Video Display Issues
Hi All, Sorry if this has been covered before but I've done a search and turned up with nothing that relates to my issue. I have also done searches on Google which turned up answers but nothing tha...
Feb 02, 2014Guru - Experienced User
The issue is almost certainly because the ReadyDLNA server is not rescanning the media. The media is there, which is why you see the folders on the laptop.
Often this problem is provoked by an out-of-spec media file, which causes the scanning process to crash.
Perhaps start by upgrading to the 6.1.6 beta firmware - it does have a couple of fixes to ReadyDLNA.
If the failure persists, you can look though the ReadyDLNA log to try and sort it out - or switch to plex and see if it works better for you.
