aalexandrebeta
May 23, 2016Master
Purchase an other RDN 316 or adding a EAD500
Any one can give me an advice concernig the options I have?
- May 23, 2016
The RN316 is more expensive, but is more flexible and gives you another slot. So I'd go for the RN316 myself.
One caveat - if you are running plex or readydlna, then each RN316 would show up as its own media server. The EDA500 wouldn't do that.
May 23, 2016Guru - Experienced User
- aalexandrebetaMay 23, 2016Master
Thank you for the tip!
By the way sorry for being grumpy here but your devices are not well spread and advertise nor available with a good price in France.
any mean to correct that major issue, I end up with Synology or Qnap!
- StephenBMay 24, 2016Guru - Experienced User
aalexandrebeta wrote:
...but your devices are not well spread and advertise nor available with a good price in France.
They aren't my devices - I don't work for Netgear.
- aalexandrebetaJun 02, 2016Master
Thanks anyway for your help and making good suggestions!
