aalexandrebeta
May 23, 2016Master
Purchase an other RDN 316 or adding a EAD500
Any one can give me an advice concernig the options I have?
- May 23, 2016
The RN316 is more expensive, but is more flexible and gives you another slot. So I'd go for the RN316 myself.
One caveat - if you are running plex or readydlna, then each RN316 would show up as its own media server. The EDA500 wouldn't do that.
May 23, 2016Guru - Experienced User
aalexandrebeta
May 23, 2016Master
Thank you for the tip!
By the way sorry for being grumpy here but your devices are not well spread and advertise nor available with a good price in France.
any mean to correct that major issue, I end up with Synology or Qnap!
- StephenBMay 24, 2016Guru - Experienced User
aalexandrebeta wrote:
...but your devices are not well spread and advertise nor available with a good price in France.
They aren't my devices - I don't work for Netgear.
- aalexandrebetaJun 02, 2016Master
Thanks anyway for your help and making good suggestions!
