aks-2
Aug 23, 2021Apprentice
PuTTY terminal width: ps output
In a PuTTY terminal window, I am struggling to get ps to display the full command line for long commands, despite trying to override the output width. Ideally, I'd like to get ps to wrap. I tried: p...
aks-2
Note, I also tried to get ps to ignore termnal width by adding w w :
ps axfww
Lines still chopped at terminal width.
- StephenBAug 24, 2021Guru - Experienced User
ps axfww
Odd, as I'm not seeing that. ps efx truncates, but ps efxww wraps.
Have you tried piping it through something else (for instance grep).
- aks-2Aug 24, 2021Apprentice
I literally have no idea what's happened, I just retried all the combinations from yesterday, all wrap fine :smileysurprised:!
I did not reboot the ReadyNAS, but I have rebooted the PC (Win10). I was very confused as this obviously worked in the past, and I just started to wonder whether it was 'broken' by the recent patch/update.
I am running 6.10.5 Hotfix 1.
