IcyK
Jun 08, 2013Tutor
Q: compiling kernel modules on OS6 (dvb_hdhomerun)
I'm trying to get the hdhomerun working under OS6 but no success... I downloaded the GPL sources for 6.0.6 and unpacked them in /home/admin/linux. then made a symlink in usr/src/linux pointing to...
IcyK
Jun 10, 2013Tutor
After some research I now think the cause is the absence of CONFIG_DVB_CORE=m in the kernel .config.
Can anyone give me a pointer whether (and how) it is possible to hack a homebrew kernel in the Readynas?
It will be a kernel built on the nas itself with the kernel and .config from the Netgear GPL package for OS 6.0.6, the only change being CONFIG_DVB_CORE=m
I bought this (used) Ultra 2 specific for this purpose (to play with, that is) and if all goes wrong the only loss is the purchase price.
I do have some experience with soldering and RS232/TTL connections.
Or is it possible to hack the homebrew kernel in a regular firmware binary?
Thanks in advance!
Thanks in advance!
