jason92s
Jul 09, 2015Aspirant
Question about document conflicts on a NAS
In our current server 2008 environment with Office 2013, whenever a user tries to open a Word document that's open by another user, they receive a popup indicating the file is in use. Will that still...
Jul 09, 2015Guru - Experienced User
No problem.
jason92s wrote: Thanks again Stephen. My manager said she had seen all kinds of reports that NAS and Office did not play well together. I appreciate your help.
Some people have reported problems here with permissions. That has different symptoms then the one you asked about (for instance not being able to open or delete a file that isn't in use). Even if all the users are in the same group, sometimes permissions misbehave. If you don't need separate accounts, then I suggest that you set up the NAS so that all the users share the same account - all you need to do is put the same credentials into Windows Credential Manager. Hopefully others who are deploying in a similar environment can chime in.
How many users would you have?
