Rburn99
Aug 06, 2015Aspirant
questions about backups and increasing storage on Readynas Pro 6
I have a ReadyNas Pro 6 with the following information 4.2.15 WD5002 (6) x-raid2 2287gb total / 92% used VERTICAL EXPANSION How to go about upgrading to 1tb disks? (I assume I would just star...
- Aug 06, 2015
Perhaps start by sorting out the backup situation.
Try entering the IP address of the PC in the host field.
Have you tried setting up a backup job involving just one share. If it does not work , post the exact settings you are using and we will take a look. Probably better to do it on a share by share basis.
Secondly I would upgrade your firmware to 4.2.27. This will not affect your data.
Third thing depends on when last the unit was factory defaulted and possibly also what disks were in it. Have a look at this article:
http://www.rnasguide.com/2011/06/22/why-you-might-want-to-factory-reset-a-x86-readynas/
You already know you will need to factory default to set dual redundancy ( done with raidar), and this is also probably the best way to do your expansion ( factory default with all disks in place and restore from backup)
The partition changes are a 3rd reason you ought to factory default.
So, start by getting your backup sorted out.
Rburn99
Thanks for the reply. Using the IP did the trick. You can put machine/folder in the host field and it will successfully connect (but Apply remains disabled. Or you can put machine in the host field and folder in the path field but then it won't successfully connect unless you replace machine name with the ip of the machine. Seems like a bit of a bug in there somewhere but.. it's sorted! :) The backup is running now.
Moving along... which of those folders contains all the configuration information? You had suggested backing up share by share. Would that have gotten the readynas configuration settings? (scrubbing, etc).
And, how do you create a restore job or accomplish a restore?
vandermerwe
Aug 06, 2015Master
No the config is not stored in a share. You can backup the config by going to the Settings tab in Frontview. Restoring the config is easy and in the same place.
as for restoring a share, it's easiest to create the shares first then setup backup jobs to pull data to each share. Restoring is easier done share by share than trying to restore the entire volume, at least I think it is.
Troubleshooting backups and restore jobs is also easier if done share by share.
- Rburn99Aug 06, 2015Aspirant
okay I see the config backup and restore functions.
Looking at the shares, I also see c which appears to be a duplicate of all the other shares (or perhaps it's something like a catalog?). I am going to have to backup these shares to multiple locations due to their size. Just out of curiosity, can it be done through windows explorer? I can see all the data that way. Or is there something extra going on behind the scenes?
You say to use the backup function to do the restores? Just switch source and destination so it's really 'backing up' from the previous backup destinations to the readynas? And again.. do I need to stick with the backup utility or drag and drop with windows explorer? Asking because at least I would get a progress bar with windows explorer.
Now I will of course have to do the reset and restore after hours. So I will need to plan for a time when it can be done. Any idea how long it will take to format or whatever it needs to do to 6 1tb or 2tb disks before I can start restoring the data?
And thanks again for bearing with me and all my questions.
