emonkia
Aug 02, 2011Aspirant
questions on ReadyNAS 3200 -> 4200 move and 16 TB limitation
In the current 4.2.17 firmware, is it still true that the only way to get 16TB+ compatibility is to factory default with 16TB+ disk space installed? I know a factory default will be required either wa...
TeknoJnky
Aug 04, 2011Hero
emonkia wrote: If the problem is the LSI controller, can we just replace the LSI controller with the model used in the new version of the RN4200?
I believe one of the jedi's commented in the past, that the controller is integrated on the motherboard, ie not replaceable.
I personally would not be paying any amount of money for a new one unless you can get garaunteed on having a new LSI controller with 3tb+ support (from your retailer/supplier), but thats just me.
