NGold10
Jul 14, 2021Aspirant
Quicken Backups cause ReadyNAS Backup Jobs to Fail
Running a Backup Job on a ReadyNAS OS 6... Pulling data FROM a USB mounted on a Mac TO a RN share... Looking at the RN Backup Job log... .QDF-backup files can cause the RN Backup Job to f...
Jul 14, 2021Guru - Experienced User
.QDF-backup files can cause the RN Backup Job to fail...
The failure is so severe it causes the mounted USB mounted on a Mac to improperly force eject during the RN Backup Job...
I've never seen this issue posted here before (wrt to ReadyNAS), and it seems likely that it would have surfaced by now.
Have you tried copying the folder to the hard drive on the Mac? That would rule out a failing USB drive.
