jluros
Jun 14, 2017Aspirant
Quota system is incorrect.
I have a RN424 with two 4 terabyte drives. I've noticed that the way ReadyNAS OS 6.7.4 (and prior versions) calculate the available space for quotas is incorrect. The maximum size should be the space...
JennC
Jun 21, 2017NETGEAR Employee Retired
- jlurosJun 21, 2017Aspirant
I'll install it, but the release notes don't suggest that it addresses the quota system. Do you have information to the contrary?
- HopchenJun 21, 2017Prodigy
Hi,
Yeah it seems some people have reported incorrect Share Consumed values (quota values) of late. Not sure if 6.7.5 addresses it, but I think NTGR is aware of it.
6.7.5 does not address my problem. It isn't that the share is reporting the wrong amount of data consumed, but that when adjusting the quota amount, the system should allow you to go up to free space + the amount currently consumed. The way it currently works is a design flaw.
