Adlopa1
Sep 21, 2011Aspirant
"Quota violation warning" & Time Machine stopped working
I've been using a ReadyNAS Ultra 4 (4.2.19) for Time Machine backups under Mac OS 10.6 and 10.7 with no problems, but today I got an alert: Disk block limit reached on volume C for user 'ReadyNAS'....
youngy
Oct 17, 2011Aspirant
Hello all,
I had the same problem occur today on a Duo with 2*1tb drives with radiator 4.1.8. I've been using the Duo for TM backups for two years with almost no issues. I too thought that TM would just start deleting old backups once the limit set in Frontview was reached. I'm now using a Macbook Pro (2010) but previously used a Macbook to backup using TM. When the error occurred, the mac locked up and I had to hard reset to get it going again. As above, system preferences say Zero kb available.
