grunnsat
Jun 09, 2014Aspirant
Radiator 4.1.13 still gets corrupted after several weeks
I have a Readynas NV+ with 4 supported disks, 1GB of RAM running Radiator 4.1.13. What happens every month or two months is this: I suddenly get a very bad read performance, videos stutter. ...
Jun 09, 2014Guru - Experienced User
The normal question here is whether the 2 GB OS partition is running out of space. If you have ssh installed, that is easy to check - "df . -h" will do it.
If not, then perhaps delete all logs (system and backup) and then see if anything changes. If the OS partition is in fact near-full, downloading the logs before deleting them can lock up the unit. So it is best not to do that.
