grunnsat
Jun 09, 2014Aspirant
Radiator 4.1.13 still gets corrupted after several weeks
I have a Readynas NV+ with 4 supported disks, 1GB of RAM running Radiator 4.1.13. What happens every month or two months is this: I suddenly get a very bad read performance, videos stutter. ...
mdgm-ntgr
Jun 09, 2014NETGEAR Employee Retired
The user for SSH is root. If you installed EnableRootSSH the root password would have been set to be the same as the admin password at the time you installed EnableRootSSH. Though they are separate passwords and can be changed separately.
