bobbiedigital
Jun 02, 2014Aspirant
Raid changing automatically
HI, I have a NAS 314, when I bought it I had one drive, I put it in and added another drive, I then bought another drive and then added that, it stayed at raid 1. I rang netgear up and they said if...
Bigbearf
Jun 09, 2014Aspirant
Have you got your issue resolved? I have a 516 with 4 TB disk. After I put in the third or greater disc the 516 expanded first and then synced the volume. It took almost 33 hours to do both. Did the reboot help? Back up your data and then I would try shutting the NAS down unplug it wait 30 seconds then cut it back on. Wait at least an hour to see if it starts resyncing the volume. This is what work for me. I did not have to do a factory reset but thought I might have to. Please post results.
Bigbearf
Sent from my iPhone using Tapatalk
Bigbearf
