bobbiedigital
Jun 02, 2014Aspirant
Raid changing automatically
HI, I have a NAS 314, when I bought it I had one drive, I put it in and added another drive, I then bought another drive and then added that, it stayed at raid 1. I rang netgear up and they said if...
bobbiedigital
Jun 10, 2014Aspirant
Thanks, Marto.
They were brand new drives straight from the shop. One would probably have data on it now after the sync'ing.
I think buying an extra drive and back up drive to complete the process would be best.
Thanks again, Marto.
bigbearf,
I have yet to buy the drives, I will get some time tomorrow and I will let you know the results. I am thinking the quickest and safest way would be to do a factory reset and then copy the data back with drives in all the slots. It's going to cost me an extra 200 for the 4tb back up drive, but ah well, I won't lose my data and I have a spare drive as well.
Thanks bibearf, I will post my results up when done.
Bobbie.
bigbearf,
Bobbie.
Marto73 wrote: Bobbie,
As you suggest, I would prefer that you backup data on first disk. Then insert all three, and Factory reset.
Stick to default X-RAID.
Are disks 2 & 3 new? If there is data on disks 2 or 3, they will not add to Volume.
See page 2 of 2 on
Regards, Marto
