bobbiedigital
Jun 02, 2014Aspirant
Raid changing automatically
HI, I have a NAS 314, when I bought it I had one drive, I put it in and added another drive, I then bought another drive and then added that, it stayed at raid 1. I rang netgear up and they said if...
bobbiedigital
Jun 15, 2014Aspirant
Finally!
I bought a backup drive, copied 3tb of data (two days) performed a reset and it now recognises 10.5 tb of space.
woohoo, thanks very much for all your help.
I performed the reset by turning off and continually pressing the reset button during boot to get to the boot menu, then I chose a factory reset using the backup button and about half an hour later it was ready after going through the setup wizard.
This should sort me out for a while.
thanks all!
thanks all!
