whitebear_99
Jun 13, 2025Aspirant
Raid5 is broken and separate raid0 and raid1?
I made the raid5 with 6 disks and used for a year. Now I my RN316 is broken then I try to connect these disks to another linux. However I checked every disks, somehow there is raid0x5disks an...
Jun 13, 2025Guru - Experienced User
whitebear_99 wrote:Now my RN316 is broken
Can you give us more information on how it failed?
- whitebear_99Jun 14, 2025Aspirant
Suddenly, `/data/` was vanished. and user home data also deleted.
- StephenBJun 14, 2025Guru - Experienced User
Loss of the volume is usually disk related (though it can also be triggered by a software crash or power cut). Likely nothing is wrong with the NAS hardware.
One option is to power down the NAS, reinsert the drives, and power up. Then get a full log zip file from the logs page. That will give useful info on what went wrong.
The logs would give me the information I asked for on the other thread. (As I noted there, please keep this on one thread going forward).
If you want me to look at the logs, then put the full zip in cloud storage (drop box, google drive, etc), and send me a private message (PM) with a link. Make sure the permissions are set so anyone with the link can download. You send a PM using the envelope icon in the upper right of the forum page.
- whitebear_99Jun 16, 2025Aspirant
I reconnect the drive to NAS again and launched.
Unfortunetly I could't login UI it says password is wrong and locked, (maybe user information is also broken)
However I can login with ssh, how can I get the log from terminal?
