whitebear_99
Jun 13, 2025Aspirant
Raid5 is broken and separate raid0 and raid1?
I made the raid5 with 6 disks and used for a year. Now I my RN316 is broken then I try to connect these disks to another linux. However I checked every disks, somehow there is raid0x5disks an...
whitebear_99
Jun 16, 2025Aspirant
There is /FILES however this directory is empty.
>You may be able to forcibly assemble the array from SSH, but let StephenB take a look at your logs to make sure you do it right.
If possible could I ask about this how to force assmble? for next attempt.
Sandshark
Jun 16, 2025Sensei
whitebear_99 wrote:If possible could I ask about this how to force assemble? for next attempt.
To give you instructions, StephenB will need to look at your logs. The specific instructions depend on the specifics of your volume (like getting the name right).
whitebear_99 wrote:There is /FILES however this directory is empty.
Nothing is empty, but the volume isn't properly mounted, so it appears so. Don't make the mistake of trying to do anything on your own except download the full log ZIP file. Doing the wrong thing most likely will make recovery impossible.
