whitebear_99
Jun 13, 2025Aspirant
Raid5 is broken and separate raid0 and raid1?
I made the raid5 with 6 disks and used for a year. Now I my RN316 is broken then I try to connect these disks to another linux. However I checked every disks, somehow there is raid0x5disks an...
whitebear_99
Jun 16, 2025Aspirant
There is /FILES however this directory is empty.
>You may be able to forcibly assemble the array from SSH, but let StephenB take a look at your logs to make sure you do it right.
If possible could I ask about this how to force assmble? for next attempt.
Jun 16, 2025Guru - Experienced User
whitebear_99 wrote:There is /FILES however this directory is empty.
I am also seeing a couple of references to a /Second path in your logs. Did you set up another volume? (perhaps the sdg USB drive???)
