Zach217
Sep 11, 2026Follower
RAID6 resync after drive failure: Data Degraded message
I have a ReadyNAS 528 that is set up for RAID6 using X-RAID, purchased in 2018. Someone else set up the system but they moved on, so I have been maintaining it for the past several years. I had 8 dri...
Sep 11, 2026Guru - Experienced User
Zach217 wrote:I had 8 drives installed and one failed a month ago, so I removed it.
You still have single drive redundancy, since you started with RAID-6. But not the two drive redundancy offered by RAID-6.
That is why you see the degraded message. Balancing, scrubbing, etc will not fix it (as you found out). None of those steps restore the original redundancy.
Replacing the failed drive would, but it sounds like you'd rather not.
Zach217 wrote:I would like to run the system with seven drives rather than purchase a replacement
Do you have any experience with the linux command line interface?
Zach217 wrote:I should add that I have 29 TB of free space
What size(s) are the remaining disks?
