zeph
Oct 24, 2013Aspirant
RAIDar 4.3.8 and JAVA
I have a ReadyNAS Ultra 2 Plus, and am running RAIDar 4.3.4 Several months ago, I removed (uninstalled) JAVA from my PC (runs Windows 7 64-bit) ... because of the numerous and frequent security iss...
zeph
Thanks Chirpa.
I would rather not install system wide Java on my PC.
Currently, I am not experiencing any problems using RAIDar 4.3.4 ... are you aware of any serious problems/issues that I could encounter by electing to just remain on RAIDar 4.3.4?
EDIT: I noticed you said "If you remove RAIDar 4.3.4 and upgrade fresh to 4.3.8". Would there be any difference if I did not first remove RAIDar 4.3.4 and installed RAIDar 4.3.8 "over top"?
