rg2go
Jun 05, 2017Aspirant
RAIDAR fallback version for MacOS: 4.3.8 worked for me
Just got a new iMac, runnng macOS Sierra 10.12.4
Fired up my ReadyNAS+ (after about a year powered down) to pull in some backed up photos.
Installed latest downlkoad RAIDAR (6.x) from download site to the iMAC.
Needed to first install Jave 7 (no problem).
Started up RAIDAR: the scan did not find the ReadyNAS+.
Scratched head, then went to my Windows 7 laptop.
Started RAIDAR on my laptop, it found the ReadyNAS+ no problem.
Checked version: RAIDAR 4.3.8 on my Windows 7 laptop.
Went back and downloaded same version 4.3.8 for MacOS to the iMAC
(Need to first go to System Preferences --> Security and allow installation of application from a non-approved Developer)
Had to also first download Java 6, before RAIDAR 4.3.8 could install on the iMac
Downloaded RAIDAR 4.3.8 to iMAC
Started RAIDAR, scan found my ReadyNAS+ no problem.
Importing pictures now
Hello Jenn,
I decided to stay with the version 4.3.8 for MacOS since it is still working for me.
I do not have time at the moment to debug why the latest version 6.x did not work.
As you said, perhaps I should have re-started the iMAc after installing Java 7.
If I run into problems which require use of 6.3, I will look into that further,
Thanks for your help.
- JennCNETGEAR Employee Retired
Hello rg2go,
RAIDar 6.3.0 should be enough and work on your Mac. It's probably the JAVA. Did you try restarting the computer?
Welcome to the community!
Hello rg2go,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- rg2goAspirant
Hello Jenn,
