jeffyd
Oct 24, 2017Aspirant
RAIDar 4.38 stuck on "UPDATE" and no Volume is showing
I was having issues re power supply (V12 error), and the READYNAS Ultra 2 was off this morning when I checked. I swapped out for a new power brick and rebooted. The readynas was'nt showing up on t...
jeffyd
oh, both disks check out fine in disk management.
jeffyd
Both disks have gree lights in raidar - still say "updating" and still no volume is being shown. I assume that my data is gone and i just need to do a factory restart?
- StephenBOct 25, 2017Guru - Experienced User
If you are running 4.2.x firmware, then you can try powering down the NAS and connecting one of the disks to a Windows PC (either with SATA or a USB-Sata adapter). There's a free utility (R-linux for windows) that should be able to read the data volume. http://www.r-tt.com/free_linux_recovery/
Note if you are using RAID-0 to span both disks, this won't work. But it should work with jbod (two volumes), XRAID, or RAID-1.
