davidr1
May 31, 2017Luminary
RAIDar diagnostics
I noticed from RAIDar diagnostics the following: NAS314
Successfully completed diagnostics
System
Disk 1 has 1 Current Pending Sectors
Logs
2017-05-11 15:45:57: home.mount: Directory /home to mou...
mdgm-ntgr
May 31, 2017NETGEAR Employee Retired
1 is not a lot, but you should certainly keep an eye on that disk.
As for the other issue it's not that important.
You could do
# mount --bind / /mnt # rmdir /mnt/home/*
# umount /mnt
and that should get rid of that message.
- davidr1May 31, 2017Luminary
hi mdgm
Thanks but:
mount --bind / /mnt
rmdir: failed to remove '/mnt/home/*': No such file or directory
though
mount --bind / /mnt
does seem syntactically correct to me???
