bedlam1's avatar
bedlam1
Prodigy
Sep 25, 2017
RAIDar diagnostics reporting "Volume swap is 100.00% full"
RAIDar diagnostics is reporting that "Volume swap is 100.00% full", what does this mean and should I be concerned?
The content of mem_info log is:
MemTotal:        1003608 kB
MemFree:           67856 kB
MemAvailable:     310184 kB
Buffers:           93972 kB
Cached:           237852 kB
SwapCached:            0 kB
Active:           467304 kB
Inactive:         231348 kB
Active(anon):     308780 kB
Inactive(anon):    73680 kB
Active(file):     158524 kB
Inactive(file):   157668 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1047420 kB
SwapFree:        1047412 kB
Dirty:               100 kB
Writeback:           296 kB
AnonPages:        366812 kB
Mapped:            73652 kB
Shmem:             15648 kB
Slab:              72244 kB
SReclaimable:      34512 kB
SUnreclaim:        37732 kB
KernelStack:        4912 kB
PageTables:        14040 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     1549224 kB
Committed_AS:    1275072 kB
VmallocTotal:   34359738367 kB
VmallocUsed:           0 kB
VmallocChunk:          0 kB
DirectMap4k:       10944 kB
DirectMap2M:     1028096 kB
The part content of volume log is
Disks:
  sda:
   HostID: 37c0f672
   Flags: 0x2000
   Size: 3907029168 (1863 GB)
   Free: 14
   Controller 0
   Channel: 0
   Model: ST2000DM001-1ER164
   Serial:
   Firmware: CC26
   Class: SATA (3)
   RPM: 7200
   SMART data
    Reallocated Sectors:            0
    Reallocation Events:            0
    Spin Retry Count:               0
    End-to-End Errors:              0
    Command Timeouts:               1
    Current Pending Sector Count:   0
    Uncorrectable Sector Count:     0
    Temperature:                    30
    Start/Stop Count:               465
    Power-On Hours:                 16704
    Power Cycle Count:              249
    Load Cycle Count:               508
    Latest Self Test:               Passed
  sdb:
   HostID: 37c0f672
   Flags: 0x2000
   Free: 14
   Controller 0
   Channel: 1
   Model: ST2000DM001-1CH164
   Serial:
   Firmware: CC44
   Class: SATA (3)
   RPM: 7200
   SMART data
    Reallocated Sectors:            1904
    Reallocation Events:            1904
    Spin Retry Count:               0
    Command Timeouts:               0
    Temperature:                    32
    Start/Stop Count:               796
    Power-On Hours:                 38430
    Power Cycle Count:              351
    Load Cycle Count:               824
  sdc:
   HostID: 37c0f672
   Flags: 0x2000
   Free: 14
   Controller 0
   Channel: 2
   Serial:
   Firmware: CC44
   Class: SATA (3)
   RPM: 7200
   SMART data
    Spin Retry Count:               0
    Command Timeouts:               1
    Temperature:                    31
    Start/Stop Count:               766
    Power-On Hours:                 38427
    Power Cycle Count:              319
    Load Cycle Count:               797
  sdd:
   HostID: 37c0f672
   Flags: 0x2000
   Free: 14
   Controller 0
   Channel: 3
   Serial:
   Firmware: CC44
   Class: SATA (3)
   RPM: 7200
   SMART data
    Reallocated Sectors:            1584
    Reallocation Events:            1584
    Spin Retry Count:               0
    Command Timeouts:               1
    Temperature:                    31
    Start/Stop Count:               805
    Power Cycle Count:              317
    Load Cycle Count:               834
=== df -h ===
Filesystem      Size  Used Avail Use% Mounted on
udev             10M  4.0K   10M   1% /dev
/dev/md0        4.0G  760M  2.7G  22% /
tmpfs           491M     0  491M   0% /dev/shm
tmpfs           491M  8.4M  482M   2% /run
tmpfs           246M  1.5M  244M   1% /run/lock
tmpfs           491M     0  491M   0% /sys/fs/cgroup
/dev/md127      5.5T  1.5T  4.0T  28% /data
/dev/md127      5.5T  1.5T  4.0T  28% /home
/dev/md127      5.5T  1.5T  4.0T  28% /apps
/dev/sdf2       2.8T  1.5T  1.3T  55% /media/USB_HDD_1
=== df -i ===
Filesystem     Inodes IUsed  IFree IUse% Mounted on
udev           124818   495 124323    1% /dev
/dev/md0            0     0      0     - /
tmpfs          125451     1 125450    1% /dev/shm
tmpfs          125451   692 124759    1% /run
tmpfs          125451    24 125427    1% /run/lock
tmpfs          125451    15 125436    1% /sys/fs/cgroup
/dev/md127          0     0      0     - /data
/dev/md127          0     0      0     - /home
/dev/md127          0     0      0     - /apps
/dev/sdf2           0     0      0     - /media/USB_HDD_1
=== maintenance history ===
device      operation  start_time           end_time             result     details
data        defrag     2017-09-14 13:33:39  2017-09-14 13:38:07  completed
data        balance    2017-09-14 13:40:59  2017-09-14 13:41:58  completed  Done, had to relocate 12 out of 1259 chunks
data        scrub      2017-09-14 19:02:13  2017-09-15 01:32:53  pass
data        scrub      2017-09-15 02:00:02  2017-09-15 07:37:10  pass
data        defrag     2017-09-17 18:15:01  2017-09-17 18:17:29  completed
data        balance    2017-09-17 18:18:02  2017-09-17 18:18:05  completed  Done, had to relocate 1 out of 1502 chunks
data        defrag     2017-09-18 23:20:16  2017-09-18 23:22:27  completed
data        balance    2017-09-18 23:38:34  2017-09-18 23:38:41  completed  Done, had to relocate 3 out of 1520 chunks
data        balance    2017-09-19 23:56:21  2017-09-19 23:57:55  completed  Done, had to relocate 40 out of 1454 chunks
data        defrag     2017-09-19 23:58:15  2017-09-20 00:00:24  completed
data        scrub      2017-09-22 02:00:01  2017-09-22 07:23:35  pass
This indicates reallocated sectors and reallocation events counts growing on 2 disks (I have 2 new disks on order)
My Readynas Pro 4 is running on ReadyNAS OS6.9.0-T62 (Beta 2).
Can anyone throw any light on the "Volume swap is 100.00% full" issue?
  • bedlam1's avatar
    bedlam1
    Sep 28, 2017
    Skywalker thanks for the offer re logs
    I am going to pass on that just for now due to other problems I have trying to replace two drives, as I only have around 2TB of data I just started a Factory Default to solve this.
    If the "Volume swap is 100.00% full" message is still there after completion I will send the logs.
  • StephenB's avatar
    My RN526 says it has a 1 GB swap partition (/dev/md1).  Possibly that's what it means.
    I suggest rebooting the NAS, and then check the RAIDar status again.
    • bedlam1's avatar
      bedlam1
      Prodigy
      Have rebooted several times and still shows "Volume swap is 100.00% full"
      Using putty I can see an entry in /dev
      Name "+md1" Size "9,1" Modify Time "Sep 26 15:50"
      I am not well enough versed in Linux to interpret that, where are you seeing your reference to dev/md1 Stephen?
      • StephenB's avatar
        root@NAS:~# swapon --show
        NAME TYPE SIZE USED PRIO
        /dev/md1 partition 1022.9M 2.2M -1
        root@NAS:~#
ProSupport for Business
