Dave_K's avatar
Dave_K
RAIDar finds, but cannot browse ReadyNAS Pro 6 - "Element not Found."
I have both a ReadyNAS NV and a ReadyNAS Pro 6 connected to my home network, along with two high end PCs running Windows 10 Pro 64 bit.  RAIDar 4.3.8 has no problem locating and running Setup for both of them from either of my PCs.  But when I click on Browse for the ReadyNAS Pro 6, ONE of my PCs responds with an error message that simply displays the fixed IP address I have assigned to the unit with my router, and says "Element not Found." It all works perfectly from my other PC.
Does anyone have any idea what might be going on here?
  • StephenB's avatar
    What happens if you go directly to the IP address in the browser?  That is, https://proipaddress/admin
      • StephenB's avatar
        The shares screen????
        Or the home page of the admin ui?
        It should be the latter (and look like the attached screenshot).
        BTW, there is no reason to be afraid to post the full 192.168.x.y addresses.  They are not routable over the internet.  As you can see from my screen shot, my pro is assigned 10.0.0.10.  That's not routable either, so you can't reach my NAS using that address.
