Warrenjelliott
Jul 29, 2015Aspirant
Raidar finds Netgear storage but says it is not accessible
Correct wording is Your NETGEAR Storage is not accessible from this computer, please check your network setting. Interestingly I was able to access it from this mac yesterday and increase my time...
- Oct 20, 2015
Hi all. Not replacing drives. Mac computers only. Re set and re booted NAS then reset Google as their double secure system didnt help. All working now with new updates.
Thanks for all your help.
mdgm-ntgr
Jul 30, 2015NETGEAR Employee Retired
Which firmware version is on this 104?
Are you running the same version of Mac OS X on each Mac? Are you using the same web browser?
Warrenjelliott
Jul 30, 2015Aspirant
version 104.
One mac the accessable one is using Maverick
The non complient one is using Yoesmite.
However now both will not log on or contect. The password is no longer accepted and the recovery email and answer does not work. We are effectively now locked out and can only access as guests.
All three have been rebooted.
- mdgm-ntgrJul 30, 2015NETGEAR Employee Retired
Can you send me a screenshot of what you see in RAIDar?
To take a screenshot press Command+Option+4 and select the area of the screen that you wish to take the screenshot of.- WarrenjelliottJul 30, 2015Aspirant
I managed to sort it thanks. Total system reboot got it sorted. Thank you for your imput.
