Warrenjelliott
Jul 29, 2015Aspirant
Raidar finds Netgear storage but says it is not accessible
Correct wording is Your NETGEAR Storage is not accessible from this computer, please check your network setting. Interestingly I was able to access it from this mac yesterday and increase my time...
- Oct 20, 2015
Hi all. Not replacing drives. Mac computers only. Re set and re booted NAS then reset Google as their double secure system didnt help. All working now with new updates.
Thanks for all your help.
Oct 17, 2015Guru - Experienced User
PC or Mac?
What version of RAIDar?
Can you ping the duo?
amator
Oct 17, 2015Aspirant
Mac, Raidar 6.0
Today I try make factory reset and now RAIDar see Duo on 192.168.1.50 (same network as I am). Now I can access setup to choose raid level.
Propobly problem is only there if I install new hard drive. When I installed new drive yesterday, setup goes automatycly after few minutes with xraid.
- StephenBOct 17, 2015Guru - Experienced User
Were you adding or replacing a drive? If replacing, did you have 2 drives installed before?
- WarrenjelliottOct 20, 2015Aspirant
