anechka_t
Dec 30, 2012Aspirant
RAIDar won't run, help!
I recently upgraded my mac to 10.7.5 and I can access ReadyNas via APF with no issues.
However, I'm unable to run RAIDar utility. When I try to run it, I get the following message:
"To open “RAIDar Uninstaller.app,” you need to install a Java SE 6 runtime, but you are not connected to the Internet.To install a Java SE 6 runtime later, open “RAIDar Uninstaller.app” again."
I am connected to the internet. I do have Java installed (though it's version 7 now: jre-7u10-macosx-x64). I get the same message when I try to run intall a new version of RAIDar from Netgear website. I'm really not sure what else to do and I would really like to turn my ReadyNas off.
Please help!
Thanks!
Please help!
Thanks!
1 Reply
- anechka_tAspirantHere's the copy of the error log file in the RAIDar directory:
java.lang.NullPointerException
[cid:0x91f58dba]send packet IOException[/192.168.1.105:49869]:java.io.IOException: Network is down
[cid:0x91f58dba]failed to send primer packet:com.infrant.jIproxy.IproxyException: failed to send packet [IOException]
