hunger
Mar 31, 2012Apprentice
RAIDator 5.3.4 for Duo v2 Photos II
I just updated from RAIDiator 5.3.4 from 5.3.3 on my Duo v2, even though when I asked it to check for updates it said it was running the latest. It appears that RAIDiator 5.3.4 tries to downgrade P...
mdgm-ntgr
Mar 31, 2012NETGEAR Employee Retired
You should have been prompted to do the firmware update.
As for the Photos II error that is to be expected. You cannot downgrade Photos II. The Photos II add-on is installed on each firmware update. You got that error because you have a newer version of Photos II installed than the version in the 5.3.4 firmware. As a result the add-on installation was aborted. Nothing to worry about. No damage was done.
