jaidank
Oct 25, 2012Aspirant
RAIDiator 4.1.10 upgrade ReadyDLNA flakey
Hi, I just upgraded my ReadyNAS Duo (v1) to 4.1.10 today (from 4.1.8 ) and ReadyDLNA (1.0.25) has started misbehaving with my Samsung TV. I watched a movie over DLNA last night. After the upgrade ...
richtoy
Nov 15, 2012Tutor
chirpa wrote: 5.3.6 and 4.2.22 also had DLNA issues, might have been the code grab used in the latest releases: http://www.readynas.com/forum/viewtopic.php?f=10&t=66989
Curious, can you try loading the previous release of ReadyDLNA, to see if its firmware issue, or just DLNA.
Download this addon, upload via FrontView>System>Update>Local. http://www.readynas.com/download/addons/4.1/ReadyDLNA_1.0.24.3.bin
Well this has worked for me :D
ReadyDLNA_1.0.25 on RAIDiator 4.1.10 was completely unuseable with both a Samsung monitor and a Samsung SMART TV. It would only find some of the files and some completely normally named directories would appear as (null) :o I tried a reboot with disk check many stop/start of the ReadyDNLA process but it had little effect. When I installed ReadyDLNA_1.0.24.3.bin normal service was resumed. I also installed the ReadyDLNA logging, in which log should I be looking for more information?
Richard
