jaidank
Oct 25, 2012Aspirant
RAIDiator 4.1.10 upgrade ReadyDLNA flakey
Hi, I just upgraded my ReadyNAS Duo (v1) to 4.1.10 today (from 4.1.8 ) and ReadyDLNA (1.0.25) has started misbehaving with my Samsung TV. I watched a movie over DLNA last night. After the upgrade ...
richtoy
Nov 15, 2012Tutor
Well I retrieved the logs from the 1.0.25 ReadyDLNA execution and they contain quite a lot of these errors that are not in the logs when I revert to the older version. If somebody from Netgear would like the full before/after logs then just PM me.
Looking more specifically I see these
Line 5427: [2012/11/14 17:24:15] upnpsoap.c:1691: warn: SoapMethod: Unknown: X_GetSemanticQueryCapabilities
Line 5428: [2012/11/14 17:24:15] upnpsoap.c:1739: warn: Returning UPnPError 401: Invalid Action
Line 5469: [2012/11/14 17:24:15] upnpsoap.c:1691: warn: SoapMethod: Unknown: X_GetSemanticList
Line 5470: [2012/11/14 17:24:15] upnpsoap.c:1739: warn: Returning UPnPError 401: Invalid Action
Line 5702: [2012/11/14 17:24:22] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 5705: [2012/11/14 17:24:22] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 5834: [2012/11/14 17:24:42] upnpsoap.c:1691: warn: SoapMethod: Unknown: X_GetSemanticQueryCapabilities
Line 5835: [2012/11/14 17:24:42] upnpsoap.c:1739: warn: Returning UPnPError 401: Invalid Action
Line 5876: [2012/11/14 17:24:42] upnpsoap.c:1691: warn: SoapMethod: Unknown: X_GetSemanticList
Line 5877: [2012/11/14 17:24:42] upnpsoap.c:1739: warn: Returning UPnPError 401: Invalid Action
Line 5925: [2012/11/14 17:24:48] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 5927: [2012/11/14 17:24:48] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 6497: [2012/11/14 17:27:09] upnpsoap.c:1691: warn: SoapMethod: Unknown: X_GetSemanticQueryCapabilities
Line 6498: [2012/11/14 17:27:09] upnpsoap.c:1739: warn: Returning UPnPError 401: Invalid Action
Line 6539: [2012/11/14 17:27:09] upnpsoap.c:1691: warn: SoapMethod: Unknown: X_GetSemanticList
Line 6540: [2012/11/14 17:27:09] upnpsoap.c:1739: warn: Returning UPnPError 401: Invalid Action
Line 6789: [2012/11/14 17:27:19] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 6847: [2012/11/14 17:27:20] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7023: [2012/11/14 17:27:23] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7025: [2012/11/14 17:27:23] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7027: [2012/11/14 17:27:23] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7029: [2012/11/14 17:27:23] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 7253: [2012/11/14 17:27:28] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7255: [2012/11/14 17:27:28] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7257: [2012/11/14 17:27:28] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 7306: [2012/11/14 17:27:28] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7308: [2012/11/14 17:27:28] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7310: [2012/11/14 17:27:28] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7312: [2012/11/14 17:27:28] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7314: [2012/11/14 17:27:28] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 7363: [2012/11/14 17:27:28] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7365: [2012/11/14 17:27:28] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 7414: [2012/11/14 17:27:28] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7416: [2012/11/14 17:27:28] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7418: [2012/11/14 17:27:28] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7476: [2012/11/14 17:27:28] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7478: [2012/11/14 17:27:28] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7480: [2012/11/14 17:27:28] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 7759: [2012/11/14 17:32:43] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7761: [2012/11/14 17:32:43] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7763: [2012/11/14 17:32:43] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 7812: [2012/11/14 17:32:43] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7814: [2012/11/14 17:32:43] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 7863: [2012/11/14 17:32:43] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 7865: [2012/11/14 17:32:43] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7867: [2012/11/14 17:32:43] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 7916: [2012/11/14 17:32:43] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7918: [2012/11/14 17:32:43] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 7967: [2012/11/14 17:32:43] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 7969: [2012/11/14 17:32:43] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 8018: [2012/11/14 17:32:44] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 8020: [2012/11/14 17:32:44] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 8069: [2012/11/14 17:32:44] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 8071: [2012/11/14 17:32:44] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 8120: [2012/11/14 17:32:44] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 8122: [2012/11/14 17:32:44] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 8171: [2012/11/14 17:32:44] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 8173: [2012/11/14 17:32:44] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 8222: [2012/11/14 17:32:44] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 8224: [2012/11/14 17:32:44] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 8273: [2012/11/14 17:32:44] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 8275: [2012/11/14 17:32:44] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 8380: [2012/11/14 17:32:44] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 8382: [2012/11/14 17:32:44] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 8565: [2012/11/14 17:33:07] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 8567: [2012/11/14 17:33:07] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 8782: [2012/11/14 17:33:20] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 8840: [2012/11/14 17:33:20] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 8842: [2012/11/14 17:33:20] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 9114: [2012/11/14 17:33:45] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 9116: [2012/11/14 17:33:45] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 9165: [2012/11/14 17:33:45] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 9167: [2012/11/14 17:33:45] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 9272: [2012/11/14 17:33:45] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 9274: [2012/11/14 17:33:45] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 9457: [2012/11/14 17:33:52] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 9459: [2012/11/14 17:33:52] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 9508: [2012/11/14 17:33:52] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 9510: [2012/11/14 17:33:52] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 9559: [2012/11/14 17:33:52] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 9735: [2012/11/14 17:33:55] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 9737: [2012/11/14 17:33:55] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 9786: [2012/11/14 17:33:55] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 9788: [2012/11/14 17:33:55] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 9837: [2012/11/14 17:33:55] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 9839: [2012/11/14 17:33:55] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 9888: [2012/11/14 17:33:55] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 9890: [2012/11/14 17:33:55] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 12201: [2012/11/14 18:25:48] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 12203: [2012/11/14 18:25:48] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 12855: [2012/11/14 18:26:35] upnpsoap.c:1299: warn: SQL error: disk I/O error
Line 12857: [2012/11/14 18:26:35] upnpsoap.c:1739: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
Line 13174: [2012/11/14 18:26:59] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 13232: [2012/11/14 18:26:59] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
Line 13351: [2012/11/14 18:27:02] sql.c:117: warn: sql_get_int_field: step failed: disk I/O error
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>2$15$5</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>30</StartingIndex><RequestedCount>20</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>
[2012/11/14 17:33:45] upnphttp.c:728: debug: SOAPAction: urn:schemas-upnp-org:service:ContentDirectory:1#Browse
[2012/11/14 17:33:45] upnpsoap.c:1679: debug: SoapMethod: Browse
[2012/11/14 17:33:45] upnpsoap.c:1219: debug: Browsing ContentDirectory:
* ObjectID: 2$15$5
* Count: 20
* StartingIndex: 30
* BrowseFlag: BrowseDirectChildren
* Filter: *
* SortCriteria: (null)
[2012/11/14 17:33:45] upnpsoap.c:1294: debug: Browse SQL: SELECT o.OBJECT_ID, o.PARENT_ID, o.REF_ID, o.DETAIL_ID, o.CLASS, d.SIZE, d.TITLE, d.DURATION, d.BITRATE, d.SAMPLERATE, d.ARTIST, d.ALBUM, d.GENRE, d.COMMENT, d.CHANNELS, d.TRACK, d.DATE, d.RESOLUTION, d.THUMBNAIL, d.CREATOR, d.DLNA_PN, d.MIME, d.ALBUM_ART, d.DISC from OBJECTS o left join DETAILS d on (d.ID = o.DETAIL_ID) where PARENT_ID = '2$15$5' limit 30, 20;
BAD SQL: SELECT o.OBJECT_ID, o.PARENT_ID, o.REF_ID, o.DETAIL_ID, o.CLASS, d.SIZE, d.TITLE, d.DURATION, d.BITRATE, d.SAMPLERATE, d.ARTIST, d.ALBUM, d.GENRE, d.COMMENT, d.CHANNELS, d.TRACK, d.DATE, d.RESOLUTION, d.THUMBNAIL, d.CREATOR, d.DLNA_PN, d.MIME, d.ALBUM_ART, d.DISC from OBJECTS o left join DETAILS d on (d.ID = o.DETAIL_ID) where PARENT_ID = '2$15$5' limit 30, 20;
[2012/11/14 17:33:45] upnphttp.c:1272: debug: HTTP RESPONSE: HTTP/1.1 500 Internal Server Error
Content-Type: text/xml; charset="utf-8"
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:X_GetSemanticQueryCapabilities xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"></u:X_GetSemanticQueryCapabilities></s:Body></s:Envelope>
[2012/11/14 17:27:09] upnphttp.c:728: debug: SOAPAction: urn:schemas-upnp-org:service:ContentDirectory:1#X_GetSemanticQueryCapabilities
[2012/11/14 17:27:09] upnpsoap.c:1679: debug: SoapMethod: X_GetSemanticQueryCapabilities
[2012/11/14 17:27:09] upnphttp.c:1272: debug: HTTP RESPONSE: HTTP/1.1 500 Internal Server Error
Connection: close
Content-Length: 398
Server: RAIDiator/4.1 DLNADOC/1.50 UPnP/1.0 ReadyDLNA/1.0.25
Date: Wed, 14 Nov 2012 16:27:09 GMT
EXT:
