DWCD
Oct 18, 2019Aspirant
RD5200 - OS Full (Device is Offline)
Hello! I have a ReadyData 5200 here and it appears that the OS has filled its volume up with logs and now I cannot access the web interface, nor will the 'OS Reinstall' Option work. When booting, it...
DEADDEADBEEF
Oct 19, 2019Apprentice
In ssh run:
du -hxd1 /
This will give you a list of directories and how much space they use up.. If for instance /var/ shows the highest usage you can then re-run the command with /var/ as argument instead
du -hxd1 /var/
and basically follow the way down until you find the dir eating up space.
- DEADDEADBEEFOct 20, 2019Apprentice
don't see a way to edit my post.. but, I missed that this was a ReadyDATA - so the steps in my post earlier do not apply here
- DWCDOct 21, 2019Aspirant
Hey guys,
Thank you for replying to my post.So I'd like to try to poke around some more but SSH isn't enabled. Is there any way I can enable it from the device itself?
Thanks!
