DWCD
Oct 18, 2019Aspirant
RD5200 - OS Full (Device is Offline)
Hello! I have a ReadyData 5200 here and it appears that the OS has filled its volume up with logs and now I cannot access the web interface, nor will the 'OS Reinstall' Option work. When booting, it...
mdgm
Oct 20, 2019Virtuoso
DWCD wrote:I've attempted to connect via SSH unsuccessfully but I was able to get into the troubleshoot/technician mode. Unfortunately, I wasn't able to find the file or log that was filling the drive up.
That's because it's a low-level diagnostic mode designed to be usable where possible when things are badly messed up (e.g. multiple failing disks and problems importing the zpool). You have to enter some commands to manually import the rpool before you can see what's filling that up.
