tjsnow
Sep 23, 2016Aspirant
1002030001 - Commit Failed #27399265
I recently changed a hard drive and lost all volume information. I worked with support to get htis issue resolved and the issue was quickly closed. I had not done a lot of testing past verifying my d...
tjsnow
Sep 24, 2016Aspirant
Using windows explorer, I have multiple shares. In one of them I cannot create a file, nor can i moe a file from a parent folder to a sub folder. In another share this works just fine. I assume this is a permissions thing (tho it worked fine before they rebuilt my volume). So I go in to modify the permissions and that is when I get the error mentioned above.
Using the admin panel does not work either. I tried to drag one folder into another and it fails to move without any error, the folder just refreshes with no change. Same thing happens when I click the button to crete a new folder. the page just refreshes and no new folder is created.
tjsnow
Additional note, I just verified that I am unable to edit/move files in any of the shares. If I try to create a file, it sais I do not have permisisons (tho the admin panel shows that read/write is enabled for everyone. If I try to rename a file (any file) I get an error that the file is in use in another program. I have already verified all my backup scripts are not running, and that nothing is using the files. But I still cannot change anything. It is as if I have read only on everything no matter what the admin panel shows. I also cannot change any settings in the admin panel because of the error mentioned above.
- mdgm-ntgrSep 25, 2016NETGEAR Employee Retired
Can you send in a fresh set of logs (see the Sending Logs link in my sig)?
Do you have a backup?- tjsnowSep 25, 2016Aspirant
I sent the logs with a link to this post. I have backed up the important stuff, but I would prefer not to reload everything if at all possible. If we are looking at a format, I may take some time to buy some more drives and back up the rest of it.
One more additional note: I completed an OS reinstall (after upgrading to the latest firmware), and am hitting the same issues. I cannot add/modify anything either through windows or through the admin panel.
Your data volume is 97% full which is extremely full. Your logs show that your data volume was forced read-only.
This system appears to have shipped with 6.0.1.
You could try backing up some data, rebooting the system and deleting some data and then see if it still gets forced read-only or not. It's recommended to keep volume usage down to about 80-85% or less.
