Babbage
Dec 13, 2014Aspirant
6.2.0 upgrade problems on RN104
Since upgrading my RN104 to 6.2.0 I've had similar problems to those listed by other users: - Unable to shutdown or reboot. Display shows appropriate message and power button LED flashes, but noth...
Babbage
Dec 29, 2014Aspirant
Time for a frustrating progress report. The backup finally finished yesterday and I removed the offending drive and thoroughly tested it with HD Tune, which reported no errors. I put it back in the NAS and decided to stick with JBOD to start with, so I could try filling up the drive again to see what happens before I commit to starting from scratch with RAID. I also upgraded to 6.2.2 after starting up the NAS. I hit two problems with re-adding the drive:
1 - I tried naming the new JBOD volume Cygnus4 the same as it was previously, only to be told this name is already in use (despite the drive having being formatted) so I had to call it Cygnus_4. Maybe I should have destroyed the volume before removing the drive?
2 - If I try to create a shared folder on this drive I get "Folder operation failed. 1013060008 Cannot get UID for Guest." Rebooting the NAS hasn't helped, so I am now stuck. I might try reinstalling the firmware again this evening after work.
