geojay
Apr 16, 2020Guide
Adding disk to volume on RN214
My RN214 currently has two 4TB disks inside, arranged as a single X-RAID volume (RAID 1). I've added a third 4TB disk and was expecting the volume to expand automatically onto the new disk. Apart fro...
Apr 16, 2020Guru - Experienced User
What happens if you select the disk on the volume tab, and the click on format in the right pane?
If the disk is formatted outside the NAS, it won't be automatically added to the array.
geojay
Apr 16, 2020Guide
Hi Stephen,
It was a brand new disk and I've tried formatting it using the Format option. This seemed to have no effect. The attached screenshot shows the current status of the disk as obtained by hovering over the disk...
Thanks
- StephenBApr 16, 2020Guru - Experienced User
geojay wrote:It was a brand new disk and I've tried formatting it using the Format option. This seemed to have no effect.
Was there any indication in the UI that formatting was actually done?
Try rebooting the NAS, and see if that triggers the expansion.
- geojayApr 16, 2020Guide
Hi Stephen,
I got the following success message from the logs:
"Volume: Disk format completed on channel 3."
I've rebooted once following the format but I'll try again...
Thanks
