geojay
Apr 16, 2020Guide
Adding disk to volume on RN214
My RN214 currently has two 4TB disks inside, arranged as a single X-RAID volume (RAID 1). I've added a third 4TB disk and was expecting the volume to expand automatically onto the new disk. Apart fro...
Apr 16, 2020Guru - Experienced User
geojay wrote:
Hi Stephen,
Where / how would I find that log file?
Thanks
Download the log zip file from the logs page.
geojay
Apr 16, 2020Guide
Thanks Stephen,
I'd not noticed that option!
I've included that log below, it doesn't look too positive...
Thanks
-- Logs begin at Thu 2020-04-16 11:21:37 GMT, end at Thu 2020-04-16 14:50:15 GMT. --
Apr 16 11:23:02 NAS-BTH rn-expand[2123]: Trying auto-extend (grow onto additional disks)
Apr 16 11:23:02 NAS-BTH rn-expand[2123]: auto_extend: Checking disk sda...
Apr 16 11:23:02 NAS-BTH rn-expand[2123]: auto_extend: Checking disk sdb...
Apr 16 11:23:02 NAS-BTH rn-expand[2123]: auto_extend: Checking disk sdc...
Apr 16 11:23:02 NAS-BTH rn-expand[2123]: sdc has enough free space for data-0 [7804599886]
Apr 16 11:23:02 NAS-BTH rn-expand[2123]: Preparing disk 0:2 (sdc,ST4000VN008,3726GB) for RAID data-0...
Apr 16 11:23:02 NAS-BTH rn-expand[2123]: prepare_disk: Prepare disk 0:2 (sdc,ST4000VN008,3726GB) with partition size 7804599855
Apr 16 11:23:02 NAS-BTH rn-expand[2123]: Found sdc is not a member of root
Apr 16 11:23:06 NAS-BTH rn-expand[2123]: Partitioning failed! [4]
Apr 16 11:23:06 NAS-BTH rn-expand[2123]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Warning! GPT main header not overwritten! Error is 5;Warning: The kernel is still using the old partition table.;The new table will be used at the next reboot or after you;run partprobe(8) or kpartx(8);GPT data structures destroyed! You may now partition the disk using fdisk or;other utilities.;Warning! MBR not overwritten! Error is 5!;Warning! Read error 5; strange be
Apr 16 11:23:06 NAS-BTH rn-expand[2123]: adding partition failed [5]
Apr 16 11:23:06 NAS-BTH rn-expand[2123]: Found sdc is not a member of swap
Apr 16 11:23:06 NAS-BTH rn-expand[2123]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Unable to save backup partition table! Perhaps the 'e' option on the experts';menu will resolve this problem.;Warning! An error was reported when writing the partition table! This error;MIGHT be harmless, or the disk might be damaged! Checking it is advisable.;
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: Partitioning failed! [4]
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Unable to save backup partition table! Perhaps the 'e' option on the experts';menu will resolve this problem.;Warning! An error was reported when writing the partition table! This error;MIGHT be harmless, or the disk might be damaged! Checking it is advisable.;
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: add_partition: Input/output error [5]
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: prepare_disk failed: Input/output error
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: Trying xraid-expand (tiered expansion)
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: Considering X-RAID auto-expansion for data
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: Checking if RAID disk sda is expandable...
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: Checking if RAID disk sdb is expandable...
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: No enough disks for data-0 to expand [need 2, have 0]
Apr 16 11:23:07 NAS-BTH rn-expand[2123]: 0 disks expandable in data
-- Reboot --
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: Trying auto-expand (in-place)
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: Considering inplace auto-expansion for data
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: Checking if RAID disk sda is expandable...
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: Trying auto-extend (grow onto additional disks)
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: auto_extend: Checking disk sda...
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: auto_extend: Checking disk sdb...
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: auto_extend: Checking disk sdc...
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: sdc has enough free space for data-0 [7804599886]
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: Preparing disk 0:2 (sdc,ST4000VN008,3726GB) for RAID data-0...
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: prepare_disk: Prepare disk 0:2 (sdc,ST4000VN008,3726GB) with partition size 7804599855
Apr 16 14:31:36 NAS-BTH rn-expand[2160]: Found sdc is not a member of root
Apr 16 14:31:40 NAS-BTH rn-expand[2160]: Partitioning failed! [4]
Apr 16 14:31:40 NAS-BTH rn-expand[2160]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Warning! GPT main header not overwritten! Error is 5;Warning: The kernel is still using the old partition table.;The new table will be used at the next reboot or after you;run partprobe(8) or kpartx(8);GPT data structures destroyed! You may now partition the disk using fdisk or;other utilities.;Warning! MBR not overwritten! Error is 5!;Warning! Read error 5; strange be
Apr 16 14:31:40 NAS-BTH rn-expand[2160]: adding partition failed [5]
Apr 16 14:31:40 NAS-BTH rn-expand[2160]: Found sdc is not a member of swap
Apr 16 14:31:41 NAS-BTH rn-expand[2160]: Partitioning failed! [4]
Apr 16 14:31:41 NAS-BTH rn-expand[2160]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Unable to save backup partition table! Perhaps the 'e' option on the experts';menu will resolve this problem.;Warning! An error was reported when writing the partition table! This error;MIGHT be harmless, or the disk might be damaged! Checking it is advisable.;
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: Partitioning failed! [4]
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: output: Warning! Read error 5; strange behavior now likely!;Warning! Read error 5; strange behavior now likely!;Creating new GPT entries in memory.;Unable to save backup partition table! Perhaps the 'e' option on the experts';menu will resolve this problem.;Warning! An error was reported when writing the partition table! This error;MIGHT be harmless, or the disk might be damaged! Checking it is advisable.;
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: add_partition: Input/output error [5]
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: prepare_disk failed: Input/output error
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: Trying xraid-expand (tiered expansion)
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: Considering X-RAID auto-expansion for data
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: Checking if RAID disk sda is expandable...
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: Checking if RAID disk sdb is expandable...
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: No enough disks for data-0 to expand [need 2, have 0]
Apr 16 14:31:42 NAS-BTH rn-expand[2160]: 0 disks expandable in data
- SandsharkApr 16, 2020Sensei - Experienced User
It certainly sounds like the drive is bad since it cannot be properly partitioned. Next step would be to mount it in the PC (via internat SATA or SATA to USB chassis/dock, and use SeaTools to test the drive. Don't rely on anything other than the full write test to find this kind of error, so be extra careful to select the right disk (full write is destructive to the data).
- geojayApr 16, 2020Guide
Sandshark,
Which of the Seagate test suite is the full write test? It's not obvious...
Thanks!
- StephenBApr 16, 2020Guru - Experienced User
geojay wrote:
Sandshark,
I suggest running both tests (though obviously you can stop if the disk fails). Each will pick up problems that the other one misses.
But to answer your question, with Seatools you select the disk, and then look in the "Basic Tests" menu. At the bottom you'll see "advanced tests". Select that, and then choose "Full Erase (SATA)"
- geojayApr 18, 2020Guide
Hi,
I've just got myself to a location where I have a machine that I can connect the drive to by SATA and have checked SeaTools and I don't have that option. I've attached a screenshot of SeaTools, I'm guessing I want the Overwrite Erase test?
Thanks!
- StephenBApr 18, 2020Guru - Experienced User
geojay wrote:
Hi,
I'm not seeing your screenshot.
There is a guide here: https://www.seagate.com/files/www-content/support-content/downloads/seatools/_shared/downloads/pdf/SeaTools-for-windows-en-us.pdf
Page 5 shows the advanced test option.
- geojayApr 19, 2020Guide
Hi,
Apologies for forgetting to attach the screenshot... As you can see, the Advanced Tests menu I'm seeing offers different options to those described in the manual and I'm not quite sure which test equates to "Full Erase (SATA)". Is Overwrite Erase the appropriate one?
Thanks
- StephenBApr 19, 2020Guru - Experienced User
geojay wrote:
Hi,
Thx. You have a different version installed than I have (likely newer).
SCT Write will zero the disk faster - it uses a specialized command that only transfers one sector of data over the SATA interface that is then written multiple times to the disk (called write same in the ATA command set).
Overwrite Erase will zero the disk one sector at a time (exercising the SATA interface more heavily).
I'd go with Overwrite Erase. I am thinking that it won't run to completion anyway (given your symptoms).
There is a third option possible (for some drives), which is to do a cryptographic erase. If a drive supports hardware encryption, then simply changing the encryption key randomizes the disk contents. You wouldn't want to do that one, as it really doesn't exercise the drive at all. It's main benefit is that it instantly ensures the entire drive contents are made unreadable, even if there are bad sectors.
