bjhills
May 03, 2019Aspirant
Admin Page not working on FrontView: ReadyNAS Duo Model RND2150
Good Evening, I'm new to the community discussions so...
I have had my Duo for 9 years with only a small number of 'issues' but this one is baffeling me.
When I use RAIDar (4.3.8) to brin up ...
937carrera
May 04, 2019Aspirant
Have you tried using another browser like Firefox? I suspect it is a SSl security issue caused by a recent Chrome update.
You should get prompted to add a security exception because of a self signed certificate
bjhills
Thanks, I can access the page through IE so it seems like it could be a setting in Chrome.
- StephenBMay 04, 2019Guru - Experienced User
What firmware are you running in the Duo?
- 937carreraMay 05, 2019Aspirant
Hah !
I prefer to access my legacy netgear stuff through IE, I was going to post about using IE but took it out as I doubted many others would still have it available to them.
This is suggesting even more that it's a SSL certificate related issue to me
In IE are you using http or https ?
- StephenBMay 05, 2019Guru - Experienced User
Actually I don't think that's the case. Generally cert issues show up as clear exceptions on the browser page, not a blank frame as we are seeing here.
There are issues with old 4.1.x firmware and all current browsers, though setting IE in "compatibility mode" can overcome most of them. That's why I asked about the firmware version. So upgrading the duo to run 4.1.16 would be my first suggestion.
Generally I use Chrome - but there is one issue there: the "SMART+" popup on the health screen comes up blank.
FireFox is actually a good choice, as it allows you to store security exceptions for the self-signed certificate stuff.
